I’ve got a Honda HR215 that cranks first pull every time an it’ll run for over an hour with absolutely no problem of any kind. When you kill it, it will not crank again until it cools down then starts right up. I’ve insulated gas line to prevent vapor lock, adjusted valves, drilled hole in gas cap And checked coil. I’m at a complete loss, any suggestions, please?
