Thank you. I’ve seen the videos (too many). So, I pulled everything off this AM. The bushings definitely do not fit properly. There is too much up and down play allowing the axel to bind when mowing. Took the bushings off and sure enough they slide on the axel without any effort. What a rip off. Got stuck with two new adjusters with the same bad bushings. American Honda probably just painted the old inventory and are selling them as the recall repair?? They are plastic alright!!
Can't Pull Mower Backwards - HRR216VLA to bearing conversion
Edit: 2 Year update 10/18/2021 - the needle bearings worked great for 2 years. I disassembled for re-greasing and found that they HAVE caused some minor damage and mushrooming to the drive shaft especially on the left side where the transmission sits and pulls against the shaft to tension the...www.lawnmowerforum.com
How can plastic stand up to friction and heat generated by the axel rotating inside the adjuster? Found a website that sells bushings made of metal. $3 for each versus $1.25 for the plastic replacement.
Has anyone tried a metal bushing instead of the plastic one
That’s too intense for me! I’m going to order the metal bushings (Extra sets too) and then cut the plastic bushing to fit as a dust cover on the opposite end. I tried that today and it made a pretty good seal versus the existing dust cover. That thing is a joke! Rolls off after each mowing.
