Honda HRX 217
polocash
https://www.hondalawnparts.com/oemp...eEJPA66cL3I2oUHGtSRQCgv63JWM_zdG9ZwFGXsJI5nac
I hit a shallow stump and my mower stopped. I could not pull cord. I turned on side after turning off gas and pulling out spark plug. I removed center bolt holding blades to part 5. I took it apart back to part 7.
I probably will order part 16 as it looks a little bent up. It started, but I found part 25 on ground I missed. I took it all back apart, but cannot figure out how to put woodruff key back in.
Any help with a better pic, video or advice would be appreciated.
polocash
This is the flywheel woodruff. Looking for the rotary blade woodruff.
polocash
I finally figured this out. There are 3 pcs that share the key. Thanks for the help. Does anyone know the torque setting for this bolt?
polocash
I cannot pull cord with spark plug out. When I remove parts 13, 16 and 23, it pulls easily.
I did not try to start it like that though. What should I do next?
