bought this online new. from the start both rear wheels would not roll backward. Took wheels, bearings and related parts and off lubed shaft and parts with red grease. Right rear wheel now rolls backward but left will not roll backwards. Defective part? Did this mower also have the "bushing" problem? Also noticed that this mower retains water if you wash it. The wheels were full of moisture and the underside of the deck trapped alot of water. I'm thinking that this is a mower that shouldn't be washed with a hose. Wont buy a honda again.
