I cut the lawn once this spring. Then I changed the oil. During the process I closed the fuel valve.
Today I started to cut the grass but left the fuel valve closed. After a minute or so, it shut down since it wasn't getting gas. I opened the valve but it still wouldn't start. It makes a sound like it is thinking about starting.
I replaced the spark plug and that had no effect. The gas filter is fine. I am considering replacing the fuel filter. It seems odd that it would work fine for the first cut and then the second cut until the fuel valve closure shut it down, but then it wouldn't start.
Any thoughts? Solutions? Thanks.
