Honda HRC216HXA Handle Bar Question
leeave96
Looking at buying one of these mowers. The handlebars appear non adjustable, but can you set the height at assembly?
Right-tab
nope, they are not adjustable
This is not true.
Starting with the K2 version, the bracket that attaches the handle to the deck has 2 bolt holes drilled in to it, giving the handlebars a high and low height setting. Using the top hole gives the handlebar about 39" in height.
"Looking at buying one of these mowers"
Its a great mower, looking forward to fall season and seeing how it will mulch the leaves...
