Honda HRB215 problem with mowing
kurb.conrad@gmail.com
Hello
I have HRB215B SXC MZBA 6015244
It mows ok for 2 or 3 feet, then stops mowing although blades are still turning
Clutch cable was replaced last year. The belt is not loose and the mower propels okay.
I am guessing that the clutch itself may be slipping. Is there anyway of testing this theory.
I dont want to replace the clutch and find out it may be something else.
Also, when I engage blade control I can move the blade by hand (it does have some resistance but not stiff resistance) and it makes a squeaky sound as I rotate the blade
Any suggestions
Thanks
Kurb
tadawson
Okay, I found this info for checking the clutch wear, but it's for the HRB216 (not sure if it applies to the HRB215)
Before checking for clutch wear make sure that the blade control free play is correct. This should be 7/8 to 1 inch
For clutch wear. With the blade control lever pushed forward against the handlebar, measure the distance between the brake plate and the driven disk
The standard measure for this should be 2.0 mm. Service limit is 0.5 mm
