Hello,
Small engine question....
The engine in the attached picture runs great but I can't turn the damn thing off w/o pulling the plug wire. The previous owner broke off the original switch, so you're looking at the replacement switch I purchased. So far, I've identified the wires circled in RED as the low oil sensor wires. I'm not concerned about using those and I've seen where other folks snip those off. The black wire circled in green goes to the ignition I believe and the yellow on the other side of the switch is the ground. In theory, shouldn't this arrangement of wires effectively work when toggling the switch? It doesn't right now, so hoping for some pointers.
Thanks
Todd
Thanks
Todd
