EricNCSU1204
- Sep 7, 2019
- 1
- 4
Mower is a 2007 Husky push mower with the Honda GCV160 engine.
I replaced the engine stop switch (little black microswitch with plunger). before you pulled back the orange bar to start the engine which depressed the plunger on the switch. you released the orange bar and it killed the engine (releases plunger).
Now with the new switch (genuine honda part), engine will not start unless the orange bar is RELEASED (plunger open) and to kill engine you pull back the orange bar (depresses plunger).
I am baffled. I checked the wire that goes from the stop switch to the ignition coil with a multimeter and its fine.
Any ideas? when running the engine runs great otherwise.
