KSlank76
- Jul 22, 2022
- 1
- 3
Hey guys and gals. Have a pressure washer with a Honda GC 190 engine. The engine purrs like a kitten when not under load. Will run like a champ forever and ever. I squeeze the trigger and I can pressure wash for roughly 5 seconds then the engine seems to bogg down and die instantly. The engine will fire back up on the first pull and go to idling perfect at an instant. I just pulled the carb a part and cleaned it all out. Didn't really find anything in carb or fuel filter in the tank. I'm not a small engine guy but it appears this thing has some sort of fuel pump on it. It's black and roundish with three hoses attached. Fuel in, fuel out, and I assume some air/pressure from the engine to make it go. Other than some engine issue, that is where I'm leaning. What are your thoughts?
Thank you
Kevin
Thank you
Kevin
