PTmowerMech
- Apr 16, 2018
- 391
- 2,999
389CM
Stamped on the block is
1445060
GCBDT
EY7X
This is off of a Honda Generator EB5000X
Trying to pull the recoil and it wouldn't budge. Thought it was locked up, so I pulled the recoil and spark plug. I put a socket on the crank, and accidentally turned it counter clock wise and it turns freely. Turn it the other way, and just before TDC on both the compression and exhaust stroke, it comes into a spot that's really hard to turn over.
With the ratchet, I can get it over that one spot. It doesn't take a huge amount of force. But none the less, still requires some force.
Now when this spot comes up, it doesn't feel like a metal on metal situation. Although it could be a metal against the side of metal.
BTW, the rockers go up and down as they're supposed to.
Also, removed the brushes, which looked a little worn, but OK. Tried spinning the engine over without the brushes attach. Also looked down into the gen motor and didn't see anything that could be binding.
Anyone got any clues about this?
1445060
GCBDT
EY7X
