Homelite Trimmer 25cc UT25154
Tater50
02/1999 Manufacture Date: Need a carb for this; but I can not find one. Any ideas? Will a later model fit?
Thanks
ID Tag was scratched bad: this is actually a UT15154!!! Thanks Cannot find anything.
BlazNT
I can not find that model number. can you double check it?
Tater50
Sticker was partially scratched off; could be ut 15154
Thanks
Tater50
Any ideas here: this is not something I use; just got tired of seeing it leaning against the wall & do not want to throw it away before I try a new carb. Does not have a lot of hours on it.
My logic, which can be wrong; is that any homelite 25cc carb would work on it; what are your thoughts? I see some Chinese brands for 25cc that cost about $15.00; thought what the heck; would only be out a small amount.
Thanks
upupandaway
..... is that any homelite 25cc carb would work on it...
Yes you are correct. any carb that can give u the right mixture will work. The catch is get one that has the same setup like the choke in your case. My homelite hedge trimmer has one off a bandit weed trimmer from way back. I recall it was walbro wt something carb. I'll check for the exact number when I get the chance or u can browse ebay find one that fits.
Tater50
I bought 2 Chinese brands and installed; runs rough; but these trimmers have been sitting for 7 yrs; will have to do a thorough clean up and go from there. Both trimmers would run awesome, then run rough like getting too much gas.
thanks for reply
