BeardedMowerinGA
- Jul 11, 2013
- 1
- 8
SENTINEL RIDING MOWER E3912-000 39" w/ Briggs and Stratton 12hp Model 282707
The mower ran when I bought it, and for half of the next day before it died. Flushed fuel lines and tank, replaced spark plug, replaced fuel filter, replaced air filter, charged battery, wouldn't crank. At the suggestion of a coworker I shot a little starter fluid into the carb while trying to crank it and it fired up and immediately died so I knew I had a carb problem. Rebuilt and cleaned carb, reinstalled - cranked right up.
Mowed for 30 minutes, hit a chunk of wood sticking up from the ground which stopped the blade(s). Engine cut off and small amount of gray smoke came off engine for a minute or so.
Will not make a sound when I turn the key now. Ahhhhhh!
I am grateful for any help!
- Cameron
NW GA
- Cameron
NW GA
