hi i'm new here but , have a lt1050 it has charging prob........?
THE DON
  • / hi i'm new here but , have a lt1050 it has charging prob........?
I put new regulator on it , still no charge? have like 21 volts ac from stator , and from the regulator center no dc but have ac ? do i need a new stator ?
Scrubcadet10
Moderator
Staff member
what's the year of the tractor? Or give the model number, it should be on a tag under the seat if you flip it up.
Actually need the engine info.
THE DON
MOD.# 13AP11CP710 MADE 05/06
Scrubcadet10
Moderator
Staff member
Star Tech is correct, this what the engine Model tag should look like.
THE DON
IM AT WORK HAVE TO GET LATER SORRY IT'S A courage 23 HP
Okay you should have the 15A 3 terminal voltage regulator. First make sure the following two things are done.
  1. The regulator case is grounded to engine and frame via the engine crankcase.
  2. That battery voltage is present at the B+ terminal. Without battery voltage present the regulator will not work.
Both of these must be present in order for the regulator to work.
THE DON
heres my info
