hi guys i need help identifying this motor need carb
ilove2fix
hi guys i need help identifying this motor need a carb for it. thanks in advance
last pic shows carb location and connection detail maybe i can use another carb same layout?
mechanic mark
Need make, model number, engine make & all numbers from engine, year, weed trimmer, pole pruner?
dougand3
Measure center to center between 2 mounting holes. If it's 30.5mm, then any cube carb from a 25cc trimmer to a Husqvarna 272 saw will fit. You need to have impulse hole match the intake impulse slot - but most are at 12 o/c. Figure out how many cc the engine is. That's a serious muffler for a little engine.
