Hi, I need to get the rear wheels off my ZTX 42. I did not realize it had the cheepo, one piece wheel/hub, or I wouldn't have bought it. I removed the bolt, applied lot's of blaster, tapped, pulled, cussed, even rode around the yard, and the damed thing will not come off. No holes to insert eye bolts to use puller. Guess I could drill a couple. Seems sad on such an expensive 42" mower.
