Help with Pedal Controls Adjustment-K46 Transmission
bartles
Working on a John Deere LT150, Model 150B501718, the forward transmission control pedal has about one-half the travel length as does
the reverse pedal. I have taken the transmission apart, clean the sumps, magnets, and filter screen and refill it with 10w-50 synthetic oil to recommended
Tuff-Torque(K46C) levels. I have purged the system.
There is an adjustment on the control rod that connects to the transmission. Is this adjustment there to even up the pedal travel or do I have other issues?
Thanks in advance!
