I recently picked up a Coleman generator with a 11HP BS engine (Engine Model 252412). It is a 1991 vintage and even had the original gen and motor manuals... It looked brand new, so I took it home. Changed the oil and checked it all out, put some gas in it and it started on the first pull. Blew a little smoke getting rid of the oil in the cylinder due to lay up. After running for about 15 mins I shut it off and it started dripping some gasoline from a hole in the bottom of the pipe that connects the air filter to the carburator inlet. Maybe a tablespoon or so... didn't leak while running. Only after shutting it off. Check the photos which identifies the hole.
Questions: Is it supposed to leak or is it supposed to have a plug in it? Does fuel leak out due to an issue with the carburator? What would fix it? Carb kit... gasket set? The manual shows the "hole" but it never identifies it or explains what it does. It does appear to be threaded but its hard to tell for sure, with all the green paint.
I attached a few files to better illustrate the issue.
