warrenpeas
- Nov 29, 2017
- 6
- 19
I removed the set screw with an allen wrench easily. Have sprayed the key down with liquid wrench 3 different times and let is set for hours even days. Should I be trying to push the key out the direction of the yellow or red arrow in my picture illustration? You can see in the picture i have already pushed it down the direction of the yellow arrow about 1.5 inches but it will not budge any further so i think im doing something totally wrong.
The other possibility of first removing the Snapper drive disk from the drive pulley has to be a last option because it is also seized on really good and is smooth with nothing to grip on to or tap on counterclockwise wise with a hammer. This is a 20 year old bad briggs engine and i just need the pulley disk and key for my new briggs engine.
