Hay Guys
LarryMc
I have a Briggs And stratton 4HP push mower, it was under water in a flood, Its been cleaned out new oil, New carburetor, New Coil, New Plug, Fresh Gas, Starts But Wont run How ever it will run it you rock it back and fourth, or keep pushing the primer bulb, Im thinking compression But Would it run at all with low compression ?
I am thinking more like some water in the fuel tank
We really need to know which 4 Hp B & S so model & code numbers please.
Catherine
LawnWorld Support
Staff member
Welcome to the forum! :)
Hopefully we can help you find an answer.
