I have a Honda h2013 and would like to convert it to run on gas or propane. If you have done this conversion please let me know how you accomplished it. I have a Garrett regulator which will meter fuel based on engine vacuum, my weak point is where to connect the fuel line from the regulator, can the existing carb be modified or do I need a venturi piece between the carb and air filter? Best sources for parts?
Thanks,
Al
Thanks,
Al
