Harmony H2103SA Blade Replacement
lurch1
No clue to the original blades - called local Honda store and best they can offer is the mulching blades (72511-758-H60). I am looking for either the standard blades or some hi-lift as I am a bagger.
I see the K-version lists (72531-758-L00/C00 and 72511-758-L00/C00) and they appear the same size (19.5 x 2.75) but unsure whats different between the two models and fit/function.
Anyone have a clue what blades will fit and replace what I have without using these mulching blades?
Thanks
mechanic mark
look at item #2 rotary blade, item #1 says mulching kit not available.
Look through these blades & see if you can find a non-mulching blade.
