This isn't about a lawnmower, but it is about a small engine. I have a trash pump with a LCT engine,(Clone). It starts great, runs good but the issue is that it stops running normally before the gas tank is empty. I did have a issue with the oil level shut off which was fixed just by adding a bit of oil to it. But now it runs about 1 hour and shuts off. Any ideas?????
