21" deck self propelled 6.5 torque 149 cc kohler with Smart Choke MODEL # 10732 WHAT A POS!! Does not have 25 hours on it . First thing that broke was Smart Choke, got that fixed, now if you pull the choke spring a tiny bit before starting it will start good. Anyway, belt for self propelled is not broke but found after taking a million parts off that is slipping big time , needs to be replaced. Is there any way on God's green earth to get this belt replaced without taking the tires off, and a million other parts to find that there is a final screw holding the belt on that you cannot reach with anything ? I cannot believe changing a drive belt can be this difficult ? Thank you
