Hi all. I've an old Troy Bilt Junior rototiller with an H35 that's not running right.
I just broke it out for the first time in a few years and it started up on the 2nd pull, but was surging at high speed. I removed the carb, cleaned the bowl, and shot carb cleaner all through it. I adjusted the float to 11/64 and put her back together and then reset the governor. Now she surges at all speeds.
I'm thinking of just replacing the carb with a cheap Chinese one (I know...). I'm pretty sure it's a Series 1 carb and was wondering if I can buy any carb that says it's for an H35. I don't see a part number on it.
Also, I need to replace the fuel line and was wondering what size this uses.
Any other tips would be great too!
Thanks!
Thanks!
