- Sep 24, 2017
- 250
- 6,437
GX270- QAG2 GCAJT
working on a log splitter, owner provided a new carburetor, it is an OEM Honda/Kei Hin carburetor, and i have double checked for the proper part number.
i have cleaned the in tank fuel filter, and cleaned the tank, replaced the fuel line as well, i have good consistent flow to the carburetor and out of the bottom drain screw. Fuel is my fresh gas.
Problem: Fire it up, first pull. runs for any where from 5 to 15 seconds, starts backfiring out of the exhaust and dies. Valve clearances are in spec and the spark stays consistent when running, doesn't cut out or anything. The only thing i haven't tried is a new spark plug. which i am about too.
