GX160 Engine help
woodywoodpecker1888
Hi,
Im looking to swap over my aerator to a Honda engine. The specific engine is this Honda GX160. However, it says it has an oil alert and I am looking for one without. Is it easy to disconnect the oil alert on these machine?
Why do you want to disconnect it or get an engine without it. It shuts the engine down if the oil level gets too low. So as long as you check the oil and keep it within the normal operating range you will never notice it is even there. But if you really want to do without it just unplug one wire.
