PTmowerMech
- Apr 16, 2018
- 396
- 3,016
Some of you guru's, please correct me if I'm wrong about this.
I'm getting some of last years left overs ready to sell this spring, and ran across this trimmer someone gave me last year. The carb was junk, so I tossed it into the "rebuild later bin" and put a new Amazon carb on it. The carb came with all the extra's. Fuel line, filter, vent, air filter and plug. Plus a couple extra primer bulbs.
Anywho, it fires right up and runs pretty good. Except the fuel us coming up and out the vent tube. Plus there was so much pressure, that it squeezed out between the fuel lines and grommet.
Long story short, I pulled the vent tube through the grommet, until it was almost there was only about 1/2" sticking out (inside) the grommet.
That seemed to solve the problem.
