I have a TroyBuilt power washer powered by a 4.5 B&S engine that uses the 795469 carb (the kind that has a priming bulb and mounts directly to the gas tank, which has a mounting plate with machined channels that forms the bottom of the carb).
I recently have had all manner of problems getting it to start. Removed and flushed out the gas tank (soaked with kerosene, then rinsed and completely dried), changed oil, replaced the carb, carb gasket/diaphragm, spark plug, air filter, etc. (kits with all that are less than $20 on Amazon). Ran fine once, but the next time I needed to use it, it would not start. Took it apart and the gas tank has a light gray sludge everywhere (even on the sides of the tank — they look almost like crystals), which needless to say had completely stopped up the carb.
I also had exactly the same thing happen recently with my gas weed eater. But my lawn tractor (Cub Cadet) is using the same gas and is running fine (knock wood).
What’s weird is that I’d been running all my stuff for years on standard regular gas (which almost certainly had some ethanol in it), but recently had found a place nearby that sells ethanol free regular gas (mostly for boaters) that I have started using in my small engines.
Any idea what this gray crud is and why it is forming? And what I can do to prevent it?
thanks,
LKB
Austin, Tx.
thanks,
LKB
Austin, Tx.
