Gravely zt52
Big Daddy123
Mower stopped moving. Won't go forward or backwards. The engine runs good and the blades engage. I need help
I’m betting that the drive belt either came off the pulley or broke. Need to get down on your back and look under the rear of the unit.
Open the bypass so you can push the mower.
If you can not push it then the brake is jambed on
This + Rivets should have you covered.
Yes, some have one and others have two, depending on manufacturers.
