Gravely ZT HD 60
Dwayne Barnhart
I have a Gravely ZT HD 60 with the 24 hp. Kawasaki engine, i have a problem with it when i fill the fuel tank. It floods the cylinders with gas when i fill it up. Can someone tell me what is causing that ?
float valve in the carb is not shutting the fuel off\Time to pull it down & clean the carb and perhaps replace the needle / seat
