This is a new Husqvarna 22 HP B&S twin V with 46 inch cut deck with mulching kit. First cut of just over 1 acre of centepede grass and weeds, weeds, weeds. The cut was perfect and the smoothest and cleaneat cut I have ever had and I have cut hundred and hundreds of yards. This mower simply skats and has all the power I need. During the entire cutting never slowed up or seemed under any strain. Just seem to be saying is that all you got.........UNTIL...I have always cleaned my riding mowers after every use. I have the biggest back pack Stihl Blower they sell. I blow everything out before putting away. I noticed as soon as I got off the mower more clipping all over the deck but when after blowing it and the engine compartment out I got down and felt around the two outboard pulleys driven by the blades belt. They were so packed I could not pull all the clipping out by hand. Finally had to take one of the plantic gaurds off one side in order to get all the clipping out. I have always mulched my grass rather than discharge the clipping. There have always bees "some clippings" between the blade pulleys but nothing like this. I don't really understand why the belt did not get so hot it started to slip or actually broke. Been thinking of just taking both this little mickey mouse plastic guards off since they both are totally open on the side facing towards the center of the deck but a little concerned it will lessen the suction I get to maintain a clean cut. I might even find myself covered over with grass clippings head to toe if I do so. I am worn out worrying about this. Is there someone out there who has had such a problem and can give me some advice. Husqvana service is useless. Oh, by the way when I cut the grass is was bone dry. I can only wonder what it would have been if it was damp or wet.
