Got rid of the no power problem, now hard to start
Todd J
You may remember from a previous post I had trouble with the B&S 27hp engine on my Bad Boy.
To recap what was done since that time:
1. New ignition coil on #2 cylinder. Old was bad, no spark
2. New B&S carb. Factory job not Chinese knockoff. Replaced it because still would not run right after new coil. Still didn't run right
3. Found exhaust push rod on #1 cylinder had come loose from rocker arm. For sure won't run right like this. Put rod back in place and adjusted valves.
After adjusting valves won't start without a shot of starter fluid, then runs fine. I have tried throttle in every position and will not start when cold. Will restart when hot.
What the Hell am I missing???
Thanks for the help.
  • / Got rid of the no power problem, now hard to start
The choke is not closing fully
Adjust the cable clamp till it closes the choke fully.
Todd J
That was it. Adjusted cable and starts up and runs fine. FINALLY....this has been a learning experience.
Thanks for all the help.
