Good fix for wheels?
H20loo
Anyone want to share your fix for wobbly wheels. I have used up my supply of good wheels.
tom3
Have taken a strip of aluminum flashing material and made a bushing for the inside of the all plastic wheel. Roll it around the bolt to get it to size. Might need to ream out the bore a little bit, need lube every so often. A strip of brass might do it better if you have it.
jp1961
Hello,
A better fix might be to use a sintered bronze bushing if the plastic wheel has enough meat to do so. I think better hardware store sell these bushings in various sizes.
Drill out the wheel and press in the bronze bushing.
Regards
Jeff
2smoked
Hello,
Regards
Jeff
Here are some photos of this method I submitted in a post from 8/17. The wheel hole was drilled out with a 5/8 inch bit.
H20loo
Thanks everyone. I will try the sheet metal first and look for the bronze bushings at the hardware store Wednesday.. There is little worse than wobbly wheels.
Doug
7394
I bored out the wheels on my old 22" MTD, & pressed in some sleeves I had laying around.
The sleeves are made outta bronze. Still working good, I do pop off the wheels at service time & grease the axle bolts. It ain't rocket science..
Folks,
My brother did a nice job of drilling out my four wheels to 5/8" (as mentioned above) and pressing in bronze bushings from True-Value. Nice and "true".
Rocky
7394
Folks,
Rocky
Rocky- Better than store bought new wheels for sure.. :thumbsup:
Mow'N Weeds
I'm assuming the felt-type spacers for these wheels are nothing available anymore?
Would a copper sleeve suffice vs bronze? I ask because I have various small pcs laying about that could be used as such.
I have one 19-in with these style wheels and they are in fact, wobbly and it bugs me. I had planned on looking into a cause and fix for the issue.
7394
Copper will work fine, but likely will wear quicker being softer.. But if you use it post up how it is doing, I have a lot of copper as well..
