Thanks for the replies. 2 questions. What do worn crankcase seals do (or not do) that causes the hard start and how much of a job is it to replace the seals
The crankcase in most 2-cycle engines like this Lawnboy is a part of the intake for the fuel-air mixture. The piston going up on compression stroke, draws fresh fuel/air mixture into the crankcase, where the fuel-oil mix coats all the bearings with the 2-cycle oil, and on the piston down-stroke, it pushes the fuel/air mixture up thru ports into the upper cylinder (the spark-plug end) where it can be compressed and ignited. If the crankshaft seals leak, it will mess with the ability of the engine to draw fresh fuel in, thus it won't start. These seals are cheap, and easy to replace, and they are a part that does and will wear out. All Lawnboys will need seals at some point. You can find U-tube videos on how to replace seals. It's very easy. The reeds, which are in the crankcase right behind the carb act as a one way valve, allowing fuel in, then blocking the passage to the carb on the down-stroke when the fuel mixture needs to be pushed into the upper cylinder. Leaky reeds can cause bad or no running, but in your case since it starts cold, this is classic symptom of leaky seals.
