Hey all,
I had an issue with surging that I fixed due to a clogged jet. I put everything back together and it works great.
However, now my throttle speed, when set to slow, will not lower RPMs. Moving from fast to slow maybe takes it down 100 or 200 RPM but it still sounds like the fast speed. What do I need to adjust to get the slow throttle setting to the proper RPMs?
