reynoldston
- May 23, 2011
- 92
- 5,705
If you replace your gas filter make sure it is large enough. I just repaired a Bolens 14 HP and when I was done it would run bad when mowing grass. I had just changed the fuel filter with a small paper one I had laying around witch I found this was a mistake. I installed a new larger paper one and problem solved.
