FW 35 Ferris walk behind no fuel
gregjo1948
This mower has a 28 hp Briggs VanGuard EFI engine. The fuel pump is working as it should but, gas isn't getting into the intake manifold. It will run if I drizzle gas down the air intake tube. Because it's EFI, I think it's not getting power to the injectors to open. I haven't found any broken wires or connections. I haven't found any fuses either. Are there fuses on these FW35 mowers? Any ideas would be appreciated, gregjo1948
Hammermechanicman
Google "briggs efi manual pdf" . Mud buddy website has the manual online. Only 150 pages.
