I bought a Husqvarna mower with a Kohler SV600S that had a crack in the block that the original owner had repaired. The engine runs perfect but most of the oil will leak out within a week. I found a replacement engine which is the SV590 that came from an MTD with a broken frame. I swapped the engines out and everything is perfect except I can not keep the engine running. One thing to note is my Husqvarna gas tank is in the rear and the MTD gas tank is mounted just behind and above the engine. On the SV600S, it has a fitting on the top of the crankcase that is connected to the vacuum line on the fuel pump. The SV590 engine does not have that fitting on the top of the engine. However, on the SV590, there is a 1/4 in breather tube that runs from the valve cover to the air intake housing, with a smaller hose that runs from the air intake housing up to the fuel pump mount but was not connected to anything when I bought the mower. Do this tube and setup serve the same purpose as the fitting on the top of the SV600 and should I connect the vacuum line to it? I have tried it but the engine still will not continue to run. When I spray gas in the carb, it starts immediately and runs strong for a couple of seconds then shuts down. There doesn't seem to be any fuel pumping out the carburetor hose from the fuel pump when I crank the engine over. So, I don't know if the fuel pump is bad or if I need to find a different way to connect the vacuum line.
