Fuel pickup brass tube on a B&S 3HP. 80202 0520
silver1
On a good carb. can these brass tubes be removed?
As you can see this one is not in good shape. I don't see the brass tube as a part,
only the plastic lower part.
Thanks
LB
I don't remember seeing the brass tube as a serviceable replacement part, just the plastic lower section.
silver1
That is what I see.........any options? Cut a tube to lenght from a different carb. and J-B weld it in? The plastic tube comes in different lengths.
