Fuel module
greenguy
Has anyone had to replace the fuel module on your IS2100Z? Mine was acting like it was running lean intermittently, dealer scanned it, no codes, installed fuel pressure gauge, turned ignition on, fuel pressure went up and then dropped with ignition off. Dealer says it needs fuel module.
greenguy
Replaced fuel module, ran great for 12 minutes, then developed a definite skip, replaced both coils, back in action.
