PTmowerMech
- Apr 16, 2018
- 394
- 3,008
Couple of questions.
I have this adjusted so that it's running good. Quick trigger response. But the head on this, which has those plastic blades, keeps turning. When I back the idle screw out very far, it'll die. And doing this while I'm also adjusting the low idle, to keep it idling. (If that makes sense). But before the blades stop turning, the engine dies from too low of idle
Is there something different about the way these heads are on a 4 mix? Or should everything adjust the same as a normal 2 cycle? If so, then I'll probably need to rebuild the carb. The low side is only backed out about 1/4 turn.
Note: I haven't checked the compression on this yet.
