This is on a model 936042. The front wheels are tight on the axles, but there's lots of room to slide back and forth. Should it be tighter? Seems like about 3/4" of travel on both wheels. When I bought this lawn tractor, some things were not assembled correctly, such as no thrust washers on the spindles below the bushings. Did they leave something else out? I noticed this when I had the wheels off to replace the tires.
Thanks
Thanks
