Front End Frame Broken - Honda HRN216VKA
chartrak
Too much bumping into fences and trees caused this. The wheels dont need to be replaced; the frame that holds the wheels does. Where can I get that piece. peparts.honda.com shows only the nut, flange, axle, axle shaft, etc. The left wheel pictured is not resting on the ground. Any thoughts? Ideas?
Try looking under the cutter housing breakdown. Note not all the hardware is shown so you must reuse some of it.
chartrak
What part is the cutter housing breakdown?
sgkent
I looked at the pictorial. See only two parts the deck itself and this cover that is part of that assembly.
#8 - 76140-VR8-N01ZA
sgkent
Google.com then Honda Mower Parts
