Nam11b
- Apr 11, 2022
- 1
- 4
I have a toro ss5000 with a Kawasaki FR691v that started popping and surging under load last season. Seems to idle fine and will drive okay, but with the blades engaged or on a slope it will start popping (I assume backfiring) and the power will noticeably drop. Power will come back for a few seconds and then will drop again.
I changed both plugs, air filter, fuel filter, oil, and fuel with no change. I pulled one plug at a time and found cylinder one would run solo, but not cylinder two. Removed and replaced both coil packs without any change. Removed and replaced the carb and now both cylinders run independently, but the mower still is popping and losing power. Verified both valves were within spec (approximately .005in). Running out of ideas, any words of wisdom?
