My mower will fire up fine, and run for about 10 to 15 minutes, then dies. It reminds me of an ignition coil problem with a vehicles. I have disassembled the top of the motor enclosure, and have found a magneto. The condition of the magneto is dirty, and partially rusty. Can I clean this with sandpaper? Does temperature effect a magneto as an ignition coil? If not, what is next to look at during the troubleshooting phase?
Thank you,
Joe
Thank you,
Joe
