Hi folks,
New to the forum, any suggestions would be greatly appreciated. I have a 08 Toro riding mower with a 20 HP B&S Intek engine. The engine quit on me while I was mowing and I did not run over any objects. After removing the flywheel cover, I discovered that the external flywheel magnet had broken off with pieces jammed into the teeth of the flywheel and starter. I'm assuming this is the reason why the engine will not start however I'm not sure I'm a complete novice when it comes to this. Can I purchase a replacement magnet or do I have to buy the flywheel assembly? The sears rep had advised that they do not sell it separately.
Could there be another reason?
Thank you in advance.
Pete
Pete
