Flywheel 16 hp B&S
Tumbleweeds
Hi Folks, New here. The flywheel on 16hp has a felt/straw like material between the magnets, is it a must, some fell out. The magnets look like they are just glued in, any suggestions, advice?
My thanks in advance,
Tumbleweeds
mechanic mark
Post Model xxxxxx, Type xxxx, Trim xx, Code xxxxxxx numbers from engine.
No it is debris that is slightly magnetic and should be removed
