Float Mode on x534 Hydraulics?
fixmdude
Hello, I've had Simplicity tractors without a hydraulic float mode and the snow blower raise/lower bar had a spring on it to force downward pressure but allow give over uneven terrain or bumps. I've also had an x700 series with a float mode on the hydraulics where you lift the lever all the way up and the snow blower sits on the ground with just its own heavy weight holding it down to scrape up packed snow. I just got a used 2010 x534 and its smaller 47" blower and I'm wondering how the hydraulics works on this model. Is there a float mode setting on the hydraulic switch or is it always on float mode with no downward pressure on this model? The plastic switch came broken so I have a new one on order, which might be in the way of me figuring it out. Thanks!
