I picked up a 14 year old Mcculloch 3616 (Husqvarna) for $10, I needed a smaller saw for fiddly bits.
Replaced perished urethane fuel lines, air filter & a full cleanup & inspect. Looks to be hardly used.
But it would not run well & was starving for fuel. I noticed the fuel tank was very pressurized, after releasing pressure it would run ok.
As the the finger pump drains back to the tank its a closed loop, excess pressure likely affecting the pump diaphram in the carby.
The fix was to make a vent, finding a high point on the tank left side I drilled a small hole & press fitted some PTFE capillary tube 1.8mm OD, It now runs well.
This might help someone with the same issue.
